How to replace Throttle Position Sensor! Help!
My engine check light came on and i ran the code from the computer and it came back as the Throttle position sensor. Car ran shitty with it messed up anyway and i tested the sensor myself and i have concluded that it is bad. I went to replace it and i realized a problem when i was at the junk yard. The a-holes at honda decided to rivit the damn thing to the throttle body. I need some advice as to how i should go about replacing it. I was thinking of using a rotozip or dremal and grinding off the heads of the rivits and then swapping the bad sensor for the good one and then drill holes and run screws in the rivit holes. Will this work? :burn:
