Results 1 to 9 of 9
Thread: Idle issue when warm
    Dec 2023
    1986 accord lxi
    Need some advice on where to start looking. I have a 1987 DX 3 door without AC. stock carb. issue is high idle when the car is warmed up. approx. 1500rpm. Fast idle unloader works and will drop idle when cold to approx 900rpm. after driving idle creeps up to approx 1500. I have replaced all the vacuum hoses and checked the diaphragms, and everything appears to work correctly or not leaking vacuum. carb float works and idle mixture appears to be correct. I am stumped.
    Here are replaced parts
    thermovalve B
    intake manifold gasket
    waterpump
    all coolant hoses
    radiator cap
    thermostat
    all vacuum lines
    fast idle unloader
    choke opener
    fuel filters (both)
    fuel lines
    just to clarify, system functions as it should when its cold but once it warms up is when the high idle issue presents itself. I have searched the forum and could not find a place to start looking. additionally, I have searched for a vacuum leak and have not found one. Any assistance or advice would be greatly appreciated.
    Feb 2023
    Honda accord 1988
    Re: Idle issue when warm
    first check the dashpot diaphragm for leaks using a hand vacuum pump, the manual states
    "If the dashpot diaphragm in the throttle controller is damaged or vacuum to the dashpot diaphragm
    is blocked or leaks, correct idle speed can not be obtained. The idle speed will be excessively high after warming up the engine."
    After that check the other diaphragms for leaks using the hand vacuum pump (don't forget about the advance timing diaphragm on the distributor)
    check for vacuum leaks on the base of the carburetor and the intake.
    Lastly you could do the brake booster test that is in the manual, perhaps it has vacuum leaks
    Good luck, this vacuum sh*t is a pain
    Sent from my 2201116SG using Tapatalk
    LX User RI86DX's Avatar
    Jul 2022
    1986 Honda Accord DX, A20A1 4SPD H4F4 AT
    Rhode Island
    I've been having the polar opposite issue. Car idles at just below 1k, like 900rpm, roll up to a stop light or stop in a driveway or whatever...bogs down to 150-200rpm and wants to die but keeps idling. This either happens after 10-15-20 seconds or sometimes it's instant. Pull off and I feel the car "lunge" forward a bit because it's suddenly getting a steady stream of fuel and is no longer struggling. This seems to only happen once the motor has warmed up just like in your case.
    Feb 2023
    Honda accord 1988
    Quote Originally Posted by RI86DX View Post
    I am not 100% sure, but i feel like your carb either needs adjustment or rebuilding
    You can adjust it by following A20A1 reply
    https://www.3geez.com/forum/showthre...djusting-Order
    But keep in mind if it is done incorrectly, it might make things worse
    Feb 2023
    Honda accord 1988
    You could also try changing the fuel filters if it has been long since they were last changed
    Jul 2022
    Rhode Island
    My last episode of wonky idle woes was solved by Seafoam. I tried that this time except I made the mistake of putting it in with a full tank of fresh gas...should've put it in before the new gas and drove around and see if it did anything. The two fuel filters are new Fram units installed last year...I've heard bad things about Fram however.
    https://www.3geez.com/forum/showthre...tick-Dieseling
    always check for loose boosters as well. All the keihin carbs had this problem. Sorry there are not pictures any more.
    As far as the original poster make sure your car is running at operating temp. If you have the thermostat out and your car runs cold the carb could start getting into the cold run circuit with choke and high idle.
    Jul 2022
    Rhode Island
    Will do, if I can't get the Keihin to stop flipping out I have the Weber K728 kit bookmarked on Carbs Unlimited..
    Carbs are pretty weather related,and elevation too, makes them frustrating to trouble shoot.
  1. Warm restart issue
    By Dr_Snooz in forum EFI Tech
    Last Post: 03-30-2023, 05:14 AM
  2. Warm Start Carb Idle Issue Solved.
    By Dr. Herb Tokyo in forum Carburetor Tech
    Last Post: 04-06-2019, 06:59 PM
  3. fast and warm idle issue with new rebuilt carb
    By lx 1986 in forum Carburetor Tech
    Last Post: 11-21-2015, 10:52 AM
  4. New twist on old issue - warm-up idle
    By omianan in forum EFI Tech
    Last Post: 05-22-2012, 10:04 PM
  5. Weber Carb - cold idle fine, warm idle too high - help?
    By it's paid for in forum Carburetor Tech
    Last Post: 02-21-2004, 09:11 PM
