Results 1 to 25 of 26
Thread: wheres the port to recharge the AC?
    LX User geeteedan's Avatar
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    noticed today that the AC air wasnt cold at all. First time ive had it on this year.
    So i figured i'd head up to wally world and get a recharge kit
    Current DD
    06 Acura TSX
    89 Accord LXI, 259k miles and counting
    98 Mustang GT weekend car
    Re: wheres the port to recharge the AC?
    out cars use the old freon its r12 and its really hard to get
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    yea, read about it all after i posted the thread...
    whats my options? Not sure if im gonna keep the car long or not.
    Current DD
    06 Acura TSX
    84Accord's Avatar
    Jun 2008
    1984 Accord LX
    Quote Originally Posted by geeteedan View Post
    ive been lucky to find some r12 refill cans on ebay and craigslist..
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    Quote Originally Posted by 84Accord View Post
    $80 for 4 cans
    haha
    i'll keep the windows down for that price
    Current DD
    06 Acura TSX
    dude it cost more at a shop to have them refile like 150 lol its really not that bad
    but you might get lucky and be onbe of the few that have the correct compressor to run r135
    they also have some that you can run you just have to do the research
    84Accord's Avatar
    Jun 2008
    1984 Accord LX
    whaaat? i found 9 cans for 140 total lol. ya just got to search around
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    how would i find out what kind of compressor i have?
    Current DD
    06 Acura TSX
    i belive it says it under the hood...
    i just refiled my civics with r134a ftw!
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    yea, my father in law just told me to get it fully flushed and add 134a
    gonna go see what type of compressor i have now
    Current DD
    06 Acura TSX
    Millington, TN
    I have like 60 pounds of the stuff.
    Phil
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    ok i am OFFICALLY AN IDIOT
    found this under the hood
    Current DD
    06 Acura TSX
    Millington, TN
    You can go online and challenge the Mvac 609 (its practical open book test) cost me $25 and then bought the freon off ebay for like 13-20 dollars a can. To me it was worth every dime.
    Before you put the R134a in change all o-rings especially the compressor and the evaporator/expasion valve o-ring. It is really simple process and higghly recommended.
    Phil
    Millington, TN
    Then o-rings deffinately need to be replaced.
    Phil
    The low pressure port is on the rubber hose front of the car. The high side is on the copper pipe near the battery. To fill it you need the AC compressor running. You may have to jump the low pressure switch to do this if it wont clutch up.
    Jan 2009
    89 Accord LXI
    Greensboro, NC
    the clutch does come on, first time i tried it last week i pushed the AC button and you could feel the rpms drop alittle while it came on. Just didnt have any cold air coming out of it, same temp air that was basically out side
    Current DD
    06 Acura TSX
    Millington, TN
    The only sure way to check your system is to put some gauges on it and see what pressures you have. No sense in charging a contaminated sytem.
    Phil
    lol i didnt change any o rings or anything when i did mine... just switched it on stuck the hose on filled it up until the one line got cold ... i now has very ice cold ac.. but i need a clutch relay as its going out lol
    http://www.youtube.com/watch?v=PqNR7PGuE1s
    Millington, TN
    The weak spot on these cars is the evaporator/expansion valve seal, then the compressor.
    I did the same thing in 1997 when I switched to R134a it works great but I had to add more to often. Its real easy to swap the o-rings and flush the system to help ensure a great tightly sealed system.
    Phil
    True , yeah its probably worth it to go ahead and replace them to be on the safe side, mine still had some freon in it though just wasn't cold cold so i didn't want to pay someone to suck the old freon out and didn't want to go to jail for spraying it in the o zone
    DX User Francos Accord's Avatar
    1989 Honda Accord
    PA
    Not to jack the thread, but what is wrong if the clutch doesnt kick in?
    ShamWow. Youll be saying WOW everytime!
    LX User mephi's Avatar
    Apr 2004
    1987 Accord DX 4 door
    Port Orchard, WA
    Quote Originally Posted by Francos Accord View Post
    You probably have either an electrical problem or low pressure. There is a sensor for pressure, and if there isn't enough, it will kill the system. Electrical problems also become common as the car gets older.
    Back to the main topic, If you do loose all of your refrigerant, it isn't a bad idea to get it properly serviced and not just add more. If there is a leak in the system and you live in a humid area, moisture can get in there. If you still had R-12, it could cause the system to become acidic and, well, aluminum and acid don't get along well. The moisture can also collect around the orifice tube or expansion valve and freeze, clogging up the system. What you generally want to do is run a near total vacuum on the system, and suck everything out. If it just won't suck down, you have a leak. Then you have to fill it with a tiny bit of refrigerant, and use a sniffer to find the leak. Once you repair the leak, you suck it down again and refill. Obviously this all requires some special equipment, but it is the best way to go. If you live in the desert though, you should be fine.
    You can also go onto the ASE web site and take the refrigerant handling and recovery test for $15. Then you can be certified to handle both R-12 and R134a and buy the stuff in larger, cheaper amounts.
    And you will know me by the cloud of smoke.
    you still got some left? my coupe needs some bad
    Get the certificate for R12 for $20, get the gauges for $30, get freon for $80. Now you're set.
    low freon or bad relay
  1. Air Conditioning recharge Questions...
    By mcs32jr1968 in forum 3geez Accords
    Last Post: 04-05-2011, 07:40 PM
  2. how to recharge air conditioning?
    By timber_cruiser in forum 3geez Accords
    Last Post: 08-02-2008, 08:40 AM
  3. So wheres that leak ?
    By topgungj in forum 3geez Accords
    Last Post: 08-18-2002, 04:30 AM
  4. A/C recharge low side pressure ?
    By vtec11 in forum 3geez Accords
    Last Post: 07-13-2002, 12:20 PM
  5. Ac recharge and conversion
    Last Post: 06-25-2002, 05:42 PM
