Results 1 to 13 of 13
Thread: AC will not turn on
    DX User richduck's Avatar
    Apr 2008
    AC will not turn on
    Searched for this but nothing came close to what I have going on. Replaced Comp, expansion valve, flushed and filled system with 134 last year. Worked great for a few weeks then just stopped working. Found a blown sub fan fuse, replaced the fuse and it worked for a couple more weeks. Now the system will not turn on at all. I have replaced the relay and the diode, AC switch light comes on so I'm guessing the switch is working. The cooling fan does not start and the idle no longer increases when switching the AC on either. I have checked the pressure switch and the system is holding freon just fine. Compressor does engaged when wired direct. What else am I missing?
    88 LXi auto completely stock, all other electrical works.
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Re: AC will not turn on
    Quote Originally Posted by richduck View Post
    If the relay under the hood is good then check to make sure you have power to it. then try jumping the pressure switch. If none of that works then check all your connections! What year is it?
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Fuse #5 inside the car, labeled rear defroster, supplies power to the ac system. I spent two weeks chasing electrical gremlins to find out this fuse was blown. Even posted a thread about it lol
    '89 SE-i Coupe
    Awaiting Garage
    Dec 2003
    Millington, TN
    But you have to trace what cause the fuse to blow if in fact it is blown.
    Phil
    2drSE-i's Avatar
    Oklahoma City
    Quote Originally Posted by nswst8 View Post
    Or just the fact that its a 20 year old fuse at this point
    '89 SE-i Coupe
    Awaiting Garage
    Dec 2003
    Millington, TN
    I'd still trace the lines.
    Phil
    Apr 2008
    Checked the fuse and all is good. I'm thinking maybe it is time to pull the switch and check that. Is there an easy way to do that?
    ^ You mean pull the strip of buttons from the climate control? 'Tis a bitch. Well, time-consuming.
    Apr 2008
    Yeah, I figured it was time consuming which is why I was asking if anyone else had some ideas before I did it. I hate taking things apart for no reason, especially when they are a pain. Won't need the air for more than 2-3 more weeks at the most but I hate it when something doesn't work right!
    Aug 2007
    1987 Accord Carbed Auto Stock
    Have you checked the switch underneath the dash at the evaporator? Just throwing it out there.
    Yeah, to get that strip out, the damn gauges need to come out and everything. It's easy to get out, the problem is the center vents on LX/LX-i/SE-i's.
    Apr 2008
    Quote Originally Posted by Pnem3 View Post
    Not yet but it is now on the list. Was hoping for something easier to check.
    2drSE-i's Avatar
    Oklahoma City
    That ones not TOO bad. If you've replaced the expansion valve you will love this job. The glovebox has to come out, but that stupid black box with retarded C clips can stay in.
    '89 SE-i Coupe
    Awaiting Garage
  1. My car goes off when I turn on the A/C
    By gscream in forum Carburetor Tech
    Last Post: 06-15-2003, 07:24 AM
  2. It Won't Even Turn Over!!!!!
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 06-08-2003, 07:44 PM
  3. **turn Off**
    By jigga89SEi in forum Classic Honda Community Chat
    Last Post: 05-28-2003, 07:02 AM
  4. Why does my system turn off when I turn on my heater?
    By 89AccordLXI666 in forum Interior & Exterior Care
    Last Post: 03-02-2003, 01:18 PM
  5. HELP can't turn key
    By toastyghost in forum Interior & Exterior Care
    Last Post: 06-30-2002, 12:14 AM
