3geez.com - One Site. Three Generations of Classic Accords
Go Back   3geez.com - One Site. Three Generations of Classic Accords > Older Accords > 1geez.com
Connect with Facebook
1geez.com The Original. 76-81 Accord.
Reply
Thread Tools
Old 04-11-2010, 06:27 AM   #1
bluesky6
Vehicle: 1977 Honda Accord CVCC
Split boot for CV joints
While crawling under the car yesterday, I noticed that one of the outer CV joint boots was damaged.
Has anyone used a split boot as a replacement? If so, would you have the part number handy?
I couldn't find one at JC Whitney. Rockauto claims the Dorman 03607 might fit...
In the meantime, the car is coming together nicely:
- fixed the o-ring and gaskets that were bleeding oil
- dumped the old coolant and changed a bunch of hoses
- Replaced all the on-car replaceable carburetor diaphragms and found that the choke pull-off diaphragm was damaged.
- Replaced sparkplugs
Next up:
- valve lash adjustment
- valve cover gasket
- oil pan gasket
The last two in the name of leak control...
- valve
bluesky6 is offline   Reply With Quote
Old 04-11-2010, 06:56 AM   Tweet this post! #2
lostforawhile
Vehicle: 1986 accord hatchback, 1998 civic, the ugly slow green slug
Re: Split boot for CV joints
waste of time, those boots don't work, at least not for long, and by this time there's already grit in the joint. it's just a matter of time until it fails. Get a good rebuild or a new axle assembly. Try Napa or Oreilies, don't buy one from advance or autozone, or the cheap chain stores. those split boots are supposed to be an emergency fix in the event you run over something and tear the boot, they don't stay on very long, if you caught it right when it tore it would last long enough to get a new boot.
lostforawhile is offline   Reply With Quote
Old 04-11-2010, 06:59 AM   #3
Vehicle: 1989 Accord LX-i
That's some nice work there. I've never used the split boots myself, but I've heard bad things about them. They don't seal right, etc.
I haven't figured out the best approach to CV boots. Replacing them is such a mess that I'm more inclined to ignore them until the axle is shot. That's still a mess, but maybe a little less so than replacing the boot.
__________________
1989 Honda Accord LX-i Coupe, MT swap, bone stock, 180k miles
"I like to take hammers, and just break stuff, just break stuff."
- Beavis
Dr_Snooz is offline   Reply With Quote
Old 04-11-2010, 07:03 AM   Tweet this post! #4
lostforawhile
Next up:
- oil pan gasket
- valve
don't forget the oil filter base gasket. it's about a 2 dollar gasket dealer only. you take off the sender, take out three bolts and it comes out. take off the oil filter first of course.
Old 04-18-2010, 02:54 PM   #5
bluesky6
Thanks, guys.
I'm not spending too much $ on the car just yet. So will probably stick with the split boots for now.
Old 04-18-2010, 03:12 PM   Tweet this post! #6
lostforawhile
Thanks, guys.
A rebuilt axle assembly isn't that much, and at least you know it won't leave you stranded. before you replace anything check your motor mounts etc, if the engine has too much play the boots can rip from over extension of the joint. same goes for a shot out suspension.
Old 04-18-2010, 09:23 PM   #7
LX-incredible
LX-incredible's Avatar
Vehicle: 88 LX-i Coupe Twins/89 SE-i Coupe/88 Suburban
Slide hammer with a axle nut welded to it. I bought 80 quality outer joints off ebay a while ago. I just install a new outer with the boot. Takes me about 20 minutes now. Not sure if the 1g axles are held together with snap rings like ours...
__________________
Originally Posted by stat1K View Post
CARDONE SUCKS.
LX-incredible is offline   Reply With Quote
Old 04-18-2010, 09:38 PM   Tweet this post! #8
lostforawhile
I know I tried to put a split boot on an 81, and it was a mess, lasted about a mile before it flew off. I really don't think it's worth the time and effort, best to replace the axle or replace the boot properly.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1geez.com Site Layout © 2009, Vibrant Forums, LLC. Forum messages may be copyrighted by the original author.
Vibrant Forums, PO Box 221172 Beachwood, OH 44122-9998
