3geez.com - One Site. Three Generations of Classic Accords
Go Back   3geez.com - One Site. Three Generations of Classic Accords > Interior/Exterior > Accord Pics & Videos
Accord Pics & Videos Post pictures of your Accord!
Reply
Thread Tools
Old 07-05-2007, 01:01 AM   #1
lostforawhile
lostforawhile's Avatar
Vehicle: 1986 accord hatchback
Lightbulb Vacuum Holding Cannister
i finally got my stupid pictures to upload by some miracle.
anyway,here are some of the vaccume storage bottle for the power brakes.
the firewall feed through i made,this bolts to the firewall
here is the bottle and the aluminum brackets i made to hold it in place
sorry about the condition of the carpet,it's going to be replaced anyway,and sorry about the blurry image,still trying to get used to the focal length of this camera
this mounts the floor behind my seat
__________________
losts86hatch.tripod.com NEED A NON CRUISE HORN CONTACT RING AND TURN SIGNAL CAM
lostforawhile is online now   Reply With Quote
Old 07-05-2007, 01:50 AM   Tweet this post! #2
Civic Accord Honda
Civic Accord Honda's Avatar
Vehicle: 1991 Honda Accord EX Coupé 5Speed AKA the rusty piece of crap
Re: some pictures of the vaccume bottle storage thingy
cool
__________________
Civic Accord Honda is offline   Reply With Quote
Old 07-05-2007, 06:11 AM   #3
lostforawhile
going to try and hook up the lines today
__________________
Old 07-05-2007, 09:16 AM   #4
coope
coope's Avatar
Vehicle: 89 accord lxi efi
what does it do
coope is offline   Reply With Quote
Old 07-05-2007, 01:27 PM   #5
lostforawhile
oh, i anticipate some vaccume problems with the dual carbs and the other cam going in,this helps store vaccume for the brake booster,so your booster always has enough vaccume even if you have a lower then normal manifold vaccume. there was no where to mount it under the hood,so it's mounted behind my seat,no one can sit behind me anyway with the seat all the way back.
__________________
Old 07-05-2007, 01:44 PM   #6
lostforawhile
that does it,my tax refund check will be here in a week,auto carpet originals HELP!!!!
__________________
Old 07-05-2007, 08:18 PM   #7
bobafett
bobafett's Avatar
Vehicle: Stock 86 Accord LXi Hatch
hey let me know how that works, I really need something like this after all the work on my motor even with a stock cam i only pull like 12 in/Hg
__________________
bobafett is offline   Reply With Quote
Old 07-05-2007, 08:33 PM   #8
lostforawhile
it should work good,people have been doing it for years,if you use it for your power brakes,you t it into the line then the check valve goes into the line before the t,in other words the vaccume input on the booster and the bottle are attached together. if you don't want to fabricate one,you can buy one ready made from summit racing,or jegs.
__________________
Old 07-09-2007, 04:38 PM   #9
lostforawhile
some more pictures of the vaccume bottle being installed
feed through from the inside,carpet is pulled back,one day i'll get my pedals installed.
bottle behind the drivers seat
AN T fitting installed in engine compartment
firebraid line from feedthrough to t fitting from underneath
i realize the check valve is on the wrong side of the bottle,i just wanted to keep rainwater out,since it started raining again. i will fix it later
__________________
Old 07-09-2007, 06:51 PM   #10
frantik
Vehicle: 89 LXi Sedan
you're a madman that vaccum bottle thing is like an analog hack hehe.. pretty cool
__________________
frantik is offline   Reply With Quote
Old 07-09-2007, 07:22 PM   #11
lostforawhile
what is an analog hack?
__________________
Old 07-09-2007, 07:38 PM   #12
Ichiban
SEi User
Ichiban's Avatar
Vehicle: Modern TNC
Doesn't the brake booster have to have a vacuum accumulator built in to it?
__________________
ICHIBAN!
"I'm full of whiskey and rifles, you?"
Ichiban is offline   Reply With Quote
Old 07-10-2007, 01:27 PM   #13
lostforawhile
it stores some,but not very much,i'm also going to use some vaccume actuators inside of the car,and this will also store vaccume for them when the car is off. some future projects.
__________________
Old 07-10-2007, 06:26 PM   #14
Ichiban
SEi User
Ichiban's Avatar
Vehicle: Modern TNC
The 2g's actually have a vacuum bottle located under the cowl, it's plumbed into the HVAC controls, I never knew it was there until I removed the cowl grille for painting. I'm sure I have a spare, you want it?
__________________
ICHIBAN!
Old 07-10-2007, 06:27 PM   #15
knarg
SEi User
knarg's Avatar
Vehicle: 89lxi hatch, volvo 240
that's pretty awesome, i must say
knarg is offline   Reply With Quote
Old 07-10-2007, 08:24 PM   #16
lostforawhile
with the one i installed,i doubt i'll need another one,lol,but thanks. this one will probably hold enough vaccume for 5 cars.
__________________
Old 07-12-2007, 08:00 PM   #17
lostforawhile
I redid a couple of things and temp hooked up the line for testing
feedthrough at firewall side
[IMG]http
T fitting in brake line engine side
feedthrough interior side,i was able to get the one i made, to fit properly,after some additional machine work.
testing for leaks
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site Layout © 3geez.com 2000-2009. Forum messages may be copyrighted by the original author.
