Results 1 to 5 of 5
Thread: A/C oil capacity?
    Dec 2003
    Millington, TN
    A/C oil capacity?
    Okay guys, alittle help needed in calculating the the correct oil charge.
    This is word for word out of the Honda manual.
    6. Add refrigerant oil after replacing the falling parts:
    Condenser........................... 30 cc (1 fl oz)
    Evaporator........................... 30 cc (1 fl oz)
    Line or hose......................... 10 cc (1/3 fl oz)
    Receiver.............................. 10 cc (1/3 fl oz)
    Compressor......................... When a new compressor is installed, drain 30 cc (1 fl oz) of refrigerant oil out of the suction fitting on the compressor, unless you are replacing any of the above parts. Then pro-rate the amount you drain by the amount you should add for the other part(s).
    Now I know that a new compressor (Keihin 4-cyl / Nippondenso 10-cyl) has 2.5 fluid ounces.
    How do you all interpret this information?
    Phil
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    Re: A/C oil capacity?
    seems to me its just telling you how much to add per part replaced. but this sentence makes no sense: then pro-rate the amount you drain you should add for the other part(s). is there a word or two missing? also, is the capasity of the new and old compressors the same? if so, then shouldnt the whole entire volume of oil in the system be 5.1 fluid ounces? or does the compressor size dictate the amount of oil the system requires?
    Dec 2003
    Millington, TN
    Its typed word for word. I've got to be the slowest typest in the world. Where I have to look back after every word.
    I'm getting just over 4 ounces. If you subtract 1oz for installing new compressor then add other part(s)
    Or should it be 2.5 ounces for the entire systems?
    Oops: corrected sentence.
    Phil
    Yeah, good luck with that one. When I converted, I too was like ???
    I ended up putting in 3 oz. That was about 4 years ago and it's still real quiet.
    Wal-Mart does sell 3 oz. pressurized cans of oil added like freon through your gauges. If you don't get enough, you can always add more that way.
    Dec 2003
    Millington, TN
    Well, thank goodness. I thought I was the only one having trouble with this.
    Phil
  1. Tranny fluid capacity
    By bscanlan in forum 3geez Accords
    Last Post: 02-28-2013, 08:02 PM
  2. coolant capacity of radiator vs. block
    By w261w261 in forum 3geez Accords
    Last Post: 05-29-2006, 11:39 PM
  3. power steering fluid capacity?
    By johnwc723 in forum 3geez Accords
    Last Post: 05-29-2006, 12:37 PM
  4. R12 AC Capacity
    By 1989accordaz in forum Classic Honda Community Chat
    Last Post: 06-30-2004, 09:55 AM
