Page 1 of 4 1234 LastLast
Threads 1 to 25 of 88
Forum: How To
Write-ups for many frequently performed repairs and modifications. READ ONLY - CLOSED FOR POSTING
  1. Sticky Thread IMPORTANT: Everything you need to know to post pics..NEWBIES READ!!
    Started by 87accordlxi, 06-10-2003 06:35 AM
    06-10-2003, 06:35 AM Go to last post
    02-17-2003, 07:38 AM Go to last post
  2. Sticky Thread IMPORTANT: Rear Disk Swap, with pics (for those with drum brakes)2021
    Started by , 05-22-2021 12:48 PM
    01-01-1970, 12:00 AM Go to last post
  1. [Engine & Transmission] Convert from Automatic to Manual Transmission
    Started by Knowledge Base Admin, 04-29-2002 02:41 PM
    2 Pages
    1 2
    09-21-2021, 07:12 PM Go to last post
  2. [Engine & Transmission] Removing Vacuum Lines
    Started by 87accordlxi, 05-16-2018 12:14 PM
    05-16-2018, 12:14 PM Go to last post
  3. [Electrical] Adding cut off (kill) switch to your Accord
    Started by Vanilla Sky, 06-09-2014 06:52 PM
    06-09-2014, 06:52 PM Go to last post
  4. how to install a aftermarket fuel pump
    Started by Tdurr, 10-15-2013 11:14 AM
    12-08-2013, 09:32 PM Go to last post
  5. How to: wire in a fuel pump relay.
    Started by Rendon LX-i, 07-28-2013 04:23 PM
    08-11-2013, 05:34 PM Go to last post
  6. [Electrical] Fix/Rebuild Combo Switch, Windshield Wiper Switch cleaning/rebuild
    Started by russiankid, 10-16-2007 01:22 PM
    07-09-2013, 07:51 PM Go to last post
  7. [Electrical] Fix/Rebuild Combo Switch, Low/High beam headlamp switch
    Started by russiankid, 07-04-2007 04:40 PM
    07-09-2013, 07:50 PM Go to last post
  8. [Engine & Transmission] Check And Fix ECU Trouble Codes With Pics
    Started by ShyBoyCA6, 01-22-2013 12:37 AM
    01-22-2013, 12:37 AM Go to last post
  9. [Appearance] How to : Custom door panel rebuild
    Started by 2oodoor, 01-18-2013 11:36 AM
    01-20-2013, 12:55 PM Go to last post
  10. [General Info] Fix Your Slow Windows
    Started by Dr_Snooz, 12-04-2012 07:28 PM
    12-15-2012, 12:52 PM Go to last post
  11. [Electrical] How To , Wire Fog Lights
    Started by ACCORD EX, 08-21-2002 12:48 PM
    11-19-2012, 01:37 PM Go to last post
  12. [Electrical] LED Front Turn Signal Lenses
    Started by Vanilla Sky, 09-27-2012 03:03 PM
    09-27-2012, 03:03 PM Go to last post
  13. [Suspension, Wheels, Tires & Brakes] Rear Caliper Upgrade, Legend Caliper (with Pics)
    Started by Legend_master, 09-19-2006 04:14 PM
    3 Pages
    1 2 3
    04-29-2012, 11:32 AM Go to last post
  14. [Electrical] Upgraded door jamb switch
    Started by YK86, 04-03-2011 07:35 PM
    04-03-2011, 07:35 PM Go to last post
  15. [Engine & Transmission] Install an inline PS filter
    Started by Dr_Snooz, 02-19-2011 12:34 PM
    03-11-2011, 04:50 PM Go to last post
  16. [Engine & Transmission] Accel Coil How-To Install
    Started by 86-lxi, 04-30-2010 07:49 AM
    04-30-2010, 07:49 AM Go to last post
  17. [Engine & Transmission] HOW TO: DIY Catch Can
    Started by 89T, 05-28-2009 06:48 PM
    05-29-2009, 07:10 PM Go to last post
  18. [Electrical] dual filament turn signal sockets
    Started by labeledsk8r, 04-19-2009 09:31 PM
    04-23-2009, 05:19 PM Go to last post
  19. [Suspension, Wheels, Tires & Brakes] Drop the front 1/2" doing the pinch fork mod
    Started by Jims 86LXI HB, 09-29-2003 10:28 PM
    08-19-2008, 05:53 PM Go to last post
  20. [Engine & Transmission] How to install an adjustable fuel pressure regulator
    Started by Pico, 01-01-2008 03:44 PM
    01-02-2008, 05:04 PM Go to last post
  21. [Appearance] Installing OEM Window Visors
    Started by MIK3, 12-03-2007 09:20 PM
    12-03-2007, 09:20 PM Go to last post
  22. [Engine & Transmission] Camshaft Seal Replacement
    Started by mushroom_toy, 11-28-2007 04:25 PM
    11-28-2007, 04:33 PM Go to last post
  23. [Electrical] Multiple Map Sensor Harness
    Started by mushroom_toy, 08-20-2007 08:20 PM
    08-22-2007, 12:41 PM Go to last post
  24. [Suspension, Wheels, Tires & Brakes] Vigor Rear Swaybar
    Started by mushroom_toy, 08-18-2007 09:30 PM
    08-18-2007, 09:31 PM Go to last post
  25. [Electrical] Power Folding Mirror Wiring
    Started by A18A, 08-03-2007 10:39 PM
    08-03-2007, 10:39 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 4 users browsing this forum. (0 members & 4 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
