Threads 26 to 50 of 88
Forum: How To
Write-ups for many frequently performed repairs and modifications. READ ONLY - CLOSED FOR POSTING
  1. Sticky Thread IMPORTANT: Everything you need to know to post pics..NEWBIES READ!!
    Started by 87accordlxi, 06-10-2003 06:35 AM
    06-10-2003, 06:35 AM Go to last post
    02-17-2003, 07:38 AM Go to last post
  2. Sticky Thread IMPORTANT: Rear Disk Swap, with pics (for those with drum brakes)2021
    Started by , 05-22-2021 12:48 PM
    01-01-1970, 12:00 AM Go to last post
  1. [Suspension, Wheels, Tires & Brakes] PROJECT: Full bodied coil overs
    Started by Legend_master, 04-20-2007 07:28 AM
    04-20-2007, 07:28 AM Go to last post
  2. [Suspension, Wheels, Tires & Brakes] 11" FRONT rotors/Type R calipers Installed
    Started by Legend_master, 08-18-2006 01:26 PM
    3 Pages
    1 2 3
    03-30-2007, 04:38 AM Go to last post
  3. [Engine & Transmission] Replace OIL FILTER BASE GASKET
    Started by 88Accord-DX, 03-03-2007 08:39 PM
    03-03-2007, 09:27 PM Go to last post
  4. [Suspension, Wheels, Tires & Brakes] Rear Disk Swap, with pics (for those with drum brakes)
    Started by OldSchoolSwap, 08-09-2002 01:16 PM
    2 Pages
    1 2
    01-26-2007, 02:45 PM Go to last post
  5. [Electrical] MSD6 Install and Wiring Mods
    Started by Knowledge Base Admin, 04-29-2002 03:15 PM
    01-10-2007, 10:26 AM Go to last post
  6. how to: wire safc to pjo with blue wire mod
    Started by 89T, 12-30-2006 09:10 PM
    12-30-2006, 09:10 PM Go to last post
  7. [Suspension, Wheels, Tires & Brakes] How To: Changing upper control arms/Install Prelude or aftermarket arms
    Started by Vinny, 08-12-2004 08:03 AM
    12-20-2006, 07:11 PM Go to last post
  8. [Electrical] Alternator wiring and Maintenance EFI or Carb
    Started by A20A1, 10-09-2005 01:19 AM
    11-30-2006, 03:58 PM Go to last post
  9. [Electrical] "Big 3" Ground Wires
    Started by shepherd79, 11-01-2006 10:18 AM
    11-01-2006, 10:18 AM Go to last post
  10. [Engine & Transmission] Make your own Cold Air Intake
    Started by Knowledge Base Admin, 04-29-2002 03:04 PM
    10-07-2006, 11:02 PM Go to last post
  11. [Appearance] Install Remove Front Bumper
    Started by Knowledge Base Admin, 08-11-2002 07:10 PM
    03-17-2006, 12:39 AM Go to last post
  12. [Engine & Transmission] Weber 32/36 - 34 - 38 Swap
    Started by A20A1, 09-22-2004 01:03 AM
    02-28-2006, 11:13 PM Go to last post
  13. [Engine & Transmission] B16 intake manifold on A20 / B20
    Started by thegreatdane, 01-23-2006 01:22 PM
    02-08-2006, 02:02 PM Go to last post
  14. [General Info] Autozone Vehicle Repair Guide
    Started by Knowledge Base Admin, 01-04-2006 11:12 AM
    01-04-2006, 11:12 AM Go to last post
  15. [Engine & Transmission] Water Pump Replacement
    Started by 88LXi/87CRXSi, 05-08-2002 12:50 PM
    11-30-2005, 06:08 PM Go to last post
  16. [Suspension, Wheels, Tires & Brakes] Rear Caliper Repair
    Started by Swap_File, 09-18-2005 06:01 PM
    09-19-2005, 01:10 AM Go to last post
  17. [Engine & Transmission] Remove & install the Distributor
    Started by 88Accord-DX, 08-18-2005 08:50 PM
    08-18-2005, 08:50 PM Go to last post
  18. Piston ring install, rod & bearing clearance
    Started by 88Accord-DX, 05-07-2005 01:18 AM
    06-14-2005, 06:38 AM Go to last post
  19. [Appearance] Remove or Clear Tailight Lense
    Started by A20A1, 03-23-2005 03:04 PM
    04-08-2005, 08:40 PM Go to last post
  20. [Engine & Transmission] Automatic Transmission, Fluid Check and Throttle Valve TV Cable Adjustment
    Started by Einstein, 05-14-2002 06:12 PM
    03-23-2005, 12:49 AM Go to last post
  21. [Electrical] Replace Combination Switch
    Started by Nice Guy Neil, 02-27-2005 03:19 PM
    03-03-2005, 08:15 PM Go to last post
  22. [Engine & Transmission] Install a block heater
    Started by Mike's89AccordLX, 01-29-2005 12:23 PM
    01-29-2005, 12:23 PM Go to last post
  23. [Engine & Transmission] Running Keihin 2bbl Carburetor without emissions or electronic contorls.
    Started by ACCORD EX, 12-23-2002 09:07 AM
    11-24-2004, 11:38 PM Go to last post
  24. [Engine & Transmission] Adjusting Valve Lash and Clearance
    Started by Knowledge Base Admin, 04-29-2002 03:01 PM
    11-09-2004, 08:39 PM Go to last post
  25. [Electrical] How To , Wire JDM B20A To USDM PK2 ECU
    Started by carotman, 03-14-2004 09:47 PM
    10-06-2004, 10:12 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 1 users browsing this forum. (0 members & 1 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
