I am due for an oil change & tranny fliud change!! Does the tranny fliud have to be Honda brand? if so, where can I get it? Also PS sterring Fluid, where can i get that?
you can probably go to any honda dealer and get all that stuff, but i dont think it has to be a special brand or anything
btw... mat, the hell are you doin up at 6:50 man? lol
[b][color=royalblue] ty for the reply..i went to bed early...plus I gotta get ready for the meet...[b][color]:lol
yeah colors didn't work
For the tranny fluid you should use Castol Dexron, 10w-30 oil, and Prestone PS fluid.......well thats what i use anyway
for manual trans i used castrol syntec 10W-30. and for PS you have to use HONDA power steering. it says in the manual. if you don't you will damage it.
shit your right about the PS fluid, but i havent experienced any problems
The Honda Transmission fluid is expensive but thats the only stuff i have used and had to buy it too many times when i had tranny problems with my other accord. I may try some other stuff when i do a swap but dont know.
just get it from Wal mart. It is the Quakerstate brand. It should say, for honda and acura that use Dexron II.
u can buy the ps fluid at wal-mart, and it is for honda'a... it's not expensive at all.... it works great too... hope that helps
yeah, you totally have to make sure the ps fluid is honda compatable, if you dont itll leak like a mofo cuz it kills the seals. As for ATF the honda stuff is best, but any dex II or III will work. Even tho the honda automatics hold like 8 or so qts of tranny oil, youll only be able to get about 2 quarts out at a time, kinda diluting it when you change it
