Originally posted by Xulfiqar
check your check valve in your transmission - maybe its stuck to high pressure
and its normal to see some fluid jump around in the reservior when the steering is turned. - tell me something else - is the pulley the same size as the original. coz if not then the pump would be pumping too fast or too slow
The pump has an internal over-pressure valve. The pump speed doesn't matter much as long as it doesn't spin too slow at idle to give enough assist. As higher rotating speeds all of the excess pressure is relieved through the internal valve.
