gyates93
It should be fairly easy to tell if your calipers are sticking.. Check the condition of the piston and see how easy it is to move when you try to compress it to do your brake job. Also, have a look at the bolts that the caliper slides on. Everything should be greased and moving freely. If you warped a set of rotors in 1500 miles you either have very sub-par rotors or there's something going on to create some serious heat. This could mean a frequent heavy foot on the brake. Switching to ceramic pads could also help.
