spring length...4" vs 6" vs 8"
the 90-97 skunk2 kit has four 8" 8kg/mm springs (about 440lb/inch), the rear setup allows the drop range I was looking for, but when fully adjusted down the front drop is less than I want by about 1" to 1 1/2". I need to get a 6" or 4". Skunk2 sells a 6" 8kg/mm , landrum has a 4" 400lb/inch, hypercoil has a 4" 400lb/inch. I've got enough sleeve adjustment to use any of them but I'm wondering about the differences between a 4" and 6" coil. Ground Control has a 6" 450lb/inch. Another factor is that I've got 440lb/inch on the rear. Looking for advice. Thanks.
Re: spring length...4" vs 6" vs 8"
If getting revalved sturts is not part of the program, your not going to truely benefit in a positive way from those spring rates. I would not get the 4" springs, they go from their unloaded stiffness to max stiffness much faster than a 6" spring.
How much lowering do you plan to dial in?
I know a way you could get 4 revalved Bilstein's for about the price of 4 standard Koni special's. But only one person can have such a deal. You are the perfect canidate for it.
