Re: Ignition coil question
Welcome to the site, and thanks for using the search function. I would return the TC-04A coil and get the TC-03a or look into the how to section for a MSD or other aftermarket coil.
Searching around indeed the two coils look similar, however the primary/secondary winding ratio's may be different.
A TC-04A comes up as a part for late 80's V-6 Legends OEM # 30520PH7006 or 30520-PH7-016
The TC-03A is listed for the accords, OEM # 30500PH1026
Most parts stores while have aftermarket generic coils that will work just fine. I have an msd in one and an accel in another. Just a little basic moving wires around and they work. Not sure if the instructions I found where on here or the box now lol. Like $30 if i remember correctly
Demon1024
Do you have any pictures of the aftermarket coil installed?
joshskillz
Check out the how to.a lot of good info their
