can any1 give me an estimated power rating if i were to add a pace setter header, weber 32/36 carb, anda custom cat back exhaust with a universal muffler?
15hp - 30hp ?
Though if you plan on modding the car more... saving a DC header might be a better choice in the long run.
The one member we have that had the S&S header said it's quality was about the same as pacesetter, so it's not upmarket.Quote:
Originally posted by A20A1
15hp - 30hp ?
Though if you plan on modding the car more... saving a DC or S&S header might be a better choice in the long run.
Alright then, I'll edit that out.
BTW who has the S&S?
Your lucky I just just did a search yesterday and found his post.
Kraftaroni
Otherwise I would not have remembered his name:)
Kraft really gets your noodle going doesn't it. :D
I would say probably 30 hp. Puts you about right with an LX-i, with more tuning avalible for the carb.
n/m, i wont be dricing the accord for more then a week or two, although i already got the carb for free, just need the adapter plate...but im tradin my enkeis for a b18a w/ pulleys, a 5 spd clutch and a 5 spd ECU, thats always good for about 135 hp. 125 lbs. ftt of torque ;)
its goin in ur Integra? or ur accord?
Travis
im guessin TEG tho
A little over optimistic on the torque figure I thinkQuote:
well jim, considering that the engine comes with 121 lbs ft of torque stock, i think the intake and pulleys is good for 4 horsepower, not to get hostile but i know my damn DA's
Your not being hostile, your being right:D I just knew the b18a or b only had 112lbs torque,......WRONG I had the B16 in my head. What your saying is compleatly correct.Quote:
B18C1 1797 10.0:1 170hp@7600RPM/128lb-ft@6200
B18B1 1834 9.2:1 142hp@6300RPM/127lb-ft@5200
B18C5 1797 10.6:1 195hp@8000RPM/130lb-ft@7500
2G '90-'91 Integra GS USA DB B18A1 1834 9.2:1 130hp@6000RPM/121lb-ft@5000
2G '92-'93 Integra GS USA DB B18A1 1834 9.2:1 140hp@6300RPM/121lb-ft@5200
2G '92-'93 Integra GS-R USA DB B17A1 1678 10.0:1 160hp@7600RPM/117lb-ft@7000
2G '90-'93 Integra Japan DB ZC 1590 9.0:1 119hp@6300RPM/105lb-ft@5500
2G '90-'93 Integra XSi/RSi Japan DA B16A 1595 10.2:1 158hp@7600RPM/112lb-ft@7000
