new coilovers over eibachs?
About a year ago I put tokico blues and eibach prokit on the 89 3g and I dont like the way the front sits 3-4 of an inch higher in the front then the rears. I understand that this is for steering and the weight of the engine but Im anal about these things so. I am getting ground controls and the prokit and my question is, should I get the bilstiens or the konis? I do a fair amount of road racing and will do even more when I finish the turbo B20A swap. Which is better and why? If you have first hand experience that would be great. Should i also pay for the extra cost of having them assemble for me? Thanks
Re: new coilovers over eibachs?
Keep in mind that for some really odd reason, eibach choose's to run absurdly weak rear spring rates, plus I've seen at least 2 memebers with sport lines where they sagged lower than the 1.4" they're supposed to drop.
Do not run Bilstein H.D.'s on a lowered car unless you have them revalved first. I tried them on my car and they do not have enough stiffness for even the softest lowering spring you can get. I pulled them from the car and installed Koni's, problem solved!
When you say your getting ground controls and the prokit, what do you mean?
Since your specifcally mentioned road racing I will say that I would recommend that you run either revalved Koni's or revalved Bilsteins. When I would press my car to 100% max out I could tell that I needed more spring stiffness and more strut stiffness. So I sent off my old (hardly used) Bilsteins to have them revalved to run springs even stiffer than ground controls. I had just wrapped up testing them on my H&R springs and was going to order stiffer ground controls when my car got wrecked. Yes you can run koni's with the GC's, but I've had one member running GC's and another running springs just as stiff tell me they'd like more strut power. Now, you may not be as hard core as us, I dunno. Keep in mind, that if you never mentioned road racing, I would not have done this last paragraph.
Jim C.
