How low can I go with this...
Whas up all.
I went to the 'yard and hustled a set of prelude arms today, and my next step is to buy the springs...
I wanto to go as low as possible BUT here are my specs:
Rims: 17 x 7.5 and 42mm offset
Tires: 215/40/17 summitomo
I want to do the 2" all around, but I'm worried about the wide tires(215) and inward offset (42mm) rubbing the suspension.
I'm not worried about the fenders thought, cuz I'll roll them bad boys...:cool:
That was My Next Question...
Yeah I've been doin research at automotive forums and I found some info on the "washer trick". I was wondering if it worked on our cars..
Here's a quote:
"The rear camber is corrected by shimming the upper control arms (links) outboard. Add washers between the body and upper mount. Each washer provides 1/2 degree of positive camber. A good rule of thumb is to use one washer per inch that the vehicle is lowered (i.e. if you've lowered your vehicle with an Eibach Pro-Kit (1.5" drop), use 2 washers per bolt for good measure"
