i'm ketting some 17's in about 2 weeks and i saw a picture on here with a car on 17's and it filled in that ugly gap...will i need to lower it any with 17's?
Its not gonna fill the gap. It will take up a bit of it but not all of it. I had 16's on my first coupe and it filled a lot of it but that was with original springs and struts with 180k or so. I would show you a picture but both my coupes are lowered. If you search through the pic forum a few pages back you can see my red coupe with racing hart 17s but with 1.5 drop (maybe more with the koni pertches upside down).
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6254
Check this link out for what 17's will look like on stock struts-springs. I think it sits too high and needs to be lowered-
Definitely lower it! 3geez look so tight lowered
this is the car with 17's and not lowered.
Ask yourself that questoin now
http://www.boomspeed.com/jigga225/before_drop2.jpg
I think 17's are perfect for a 3rd Gen Accord. I think a 1" drop is good for 17" rims. 17's fill it in well even when the car is stock.
imo i tihnk the car needs to be dropped around 2 inches with 17's mabey 2 1/2
I agree with Jay and Jigga. If you end up getting the right size tire, the outer diameter will remain the same as stock so the tire/fender gap will remain the same. If you want that filled look, you have to lower it at least a little. Even an inch, as Mike mentioned, will make the car look lots better.
im gettin 17's too. will 205/40 tires work good?
that's the exact size you should be getting. It'll work like a charm! Post some pics as soon as you get 'em installed....
well first i gotta pick which ones to get.
then there is the tedious task of getting the money......
if you're going with 17" wheels, try and stick to a 17x7 rather then 17x7.5 if possible. That way you'll have a little better wheel protection with the choice tire.
okay thank ill keep that in mind
