If I get an after-market carb, would it still have to use all of those vac tubes? If it does, what carb should I use, and where can I find it?
get the weber DGEV kit. you can remove all but one of the vac lines. you can get the kit from http://www.carbs.net
you can remove them now and still run just fine with a little HP increase.
How to section has the How to remove vacuum lines.
