ok my car idles good while in park but when i put it in drive or reverse with the break on it idles a little below the 1 on the tachometer, i messed with the idle screw and got it to idle good in park but in order to make it idle good in drive i have to raise the idle but then it will idle at like 2k in park.
also isnt there some kinda sensor that can be disconnected that makes the car idle a little bit lower when the break is on? were is that located because i think if i removed that it would help the idle out.
thanx
