205/45-16...what does it all mean??
I got a question about tires.... the sizes.... I THINK I know what they mean, but I'm not 100%......anyway, is what it is, is I want to get some 16" from a 97+ prelude or an s2000..... my only question, is which number is the width of the tire, then, how do I figure out what tires will fit what wheels?? thanks for all help!
Re: 205/45-16...what does it all mean??
First thing I want to stress is how important it is to be concise in what you ask, notice how your replies are done. That being said I'll try to anwer how I see your question.
205/45-16
205 is the tread width in mm
45 is the aspect ratio, it is the height of the tire in relationship to its width. It is tied to the height of the rim it will mount to (16" in this case). So, 205/50-16 is a taller tire than a 205/45-16 tire. BTW, the oem tire size for the 97-01 lude is 205/50-16
RIMS
Ok,before I address what tire size's will fit on the 3rd gen accord I want to talk about what you have to have when shopping for rims. 4x100mm bolt pattern, offset must NOT be lower than 40mm. 42mm, 43mm, and 45mm are ok as well. (45mm is required for 215mm tire widths when you do not want to roll the rear fenders).
WHAT TIRE SIZE WILL FIT (you only asked about 16" so,........)
These sizes are proper plus fitments that will never rub or require you to roll your rear fender AS LONG AS YOU OBEYED THE OFFSET INFO I LIST ABOVE. And WARNING if you go taller than oem with the tire size, you increase the risk of rubbing in the rear because the taller tire is closer to the fender lip to rub.
205/45-16
195/50-16
205/40-16 slightly undersized speedo will be off a tad
215/45-16 slightly taller than oem requires 45mm offset rim
215/40-16 slightly undersized than oem requires 45mm offset rim
205/50-16 is quite a bit taller than oem and I would not recommend the size at all.
