The idle runs a tad high and fluctuates very slightly up and down. When shifting from drive to park the idle will bounce between 1k and 2k. Just replaced emessions box and most of the vacuum lines but still going to check for leaks. If I'm not mistaken the IACV is in the emissions box so it is definitely clean. Don't know if it's related but the cruise control works like 50% of the time, shutting off randomly while in use or just not activating. I can make a short video of the idle later if it helps. I appreciate any insight into fixing this, I thought getting the emissions box back in would fix it and it did for the first 2 times but then started again.
