Originally posted by '89AccordLX(Rus)
When you say the clutch went limp do you mean the pedal didn't do anything? If so it is probably the cable, first check in the cabin for problems and then progress to the engine and check that the cable is secured everywhere it needs to be. Have someone in the car press the clutch pedal and check what is happening under the hood.
Hope this is helpful.
the peddle does nothing it feels like it is connected to nothin. i was driving along then in mid shift i couldnt put it in anygear.....probably cable but where does the cable connect? will i have to have someone tear entire clutch out just to reconnect gay cable????? if so there will be a stabbed mechanic
