I Have an 86 LX and would like to boost my HP but dont want to loose Cruise or AC if anyone could help me out it would be much appriciated.
headers, high flow cat, custom cat back with nice muffler (dynomax or Flowmaster).
Accel super coil or MSD blaster coil.
Lighter pulleys.
Colt or delta cam.
that is about it if you have emissions.
if you don't have emissions, you can slap weber, but i have no idea how you would keep AC.
You can keep your ac with the weber. it doesnt effect it. mine still works fine. your car will probably not pass emissions but you can keep the ac. not sure about cruise control mine didnt work before the weber.
There are no mods that require the a/c or cruise to be removed. Taking all the a/c components out sheds a little bit of weight, but thats about it. The a/c isnt sapping power from the crank unless its turned on. If I remember right the crusie control cable attaches to the accelerator pedal assembly so there is no reason to disable it when installing a weber or any other mods.
andy
hmm. countdown to bannage.... 3, 2, 1, *poof*
