Why Is Everyone So Down On...
... VTEC swaps into early Accords? I have a 94 SOHC VTEC from a 94 Accord EX and it fit into my 90 with no issues.
Trans matched, and at least two of the mounts matched... not sure about the one at the front of the engine on the right side of the engine compartment. Its a two piece mount, and the side that bolt directly to the motor has different spacing than the stock mount that connects to the chassis. The piece from the old engine might mount directly to the new one... but if it doesn't a fabricated piece need not be terribly complicated, nor should it cost alot of time to fabricate.
Is it the Prelude swap that no one wants to talk about? Far as I have always heard, just pull the driveline out of the Prelude and install it into the Accord... trans, axles, engine, hubs, spindles... everything. I never tried it, so I only know what I have read.
I do know that a SOHC VTEC from a 94 or 95 Accord will go right in.
Will let you all know as soon as the engine gets fired.
Re: Why Is Everyone So Down On...
Cause all the things that make it such a easy swap for you in your 4th gen or 5th gen, flat out do not apply to the 3rd gen. Pretty much might as well be another make of car. Yes it can be done, but with the amount of custom parts and custom work, drives any sane person to forget about it and move on to a powerplant that makes more sense, even knowing how nice the H22's power curve is in comparision. Cost's are simply way way to high to justify. You can buy a 4th gen and do the swap for less.
Discussing the issue anymore is totally pointless and another case of rehashing, been their done that.
