Fopr some odd reason i cannot remove the arm rest on my car. i want to paint them and cant get them off!! any suggestions
to remove the arm rest you will have to remove 4 screws.
two on each side in the front and 2 on the back under the plate.
two on the back under the plate? What do you mean by under the plate? i'll check it out i dont suppose you can get some pics of that??
Also how about removing the steering wheel??
With a small screwdriver or knife carefully pry the H centre emblem out
Take 19 ml socket unscrew the nut and pull the steering wheel off
Gee, when I removed the steering wheel I removed the Phillips screws on the back of the wheel center to remove the entire plate, horn buttons and all. I never pried out the emblem.
DX at the Honda store that is the way we do it Pop the emblem out and see
WWWWWay easier
You have to remove the entire door pannel to get the arm rest off... right? Cause the screws are behind it.
Are the screw behind the door panel. Do i have to take the whole thing off to get the handles off??
yes you have too !
( stupid design )
MIKE
thats fukin gay but gota do what u gotta do!!1
