Removed vacuum lines - few questions
Followed the combined how-to articles from shepherd79 and Michael to remove my vacuum lines. Had a few questions I could not find answered in prior threads. I have an 89 DX.<br><br>
I got everything ran as per Michael's diagram except I could not find where to run 17, 18 and 19. The only thing I have near that location (on the bottom, driver side of the manifold(?)) is a small blue plastic piece sticking out, but it only has two places to hook up hoses, not three. Any ideas here?<br><br>
My fuel/air mixture screw on the carb seems to be missing. I would have expected a hole that ran into the internals of the carb, but it appears to only be about 1/8" deep before hitting metal. Is this the plug, or is this how it would appear if the screw is missing? I guess I don't understand how the screw works if it doesn't run into the internals of the carb. <br><br>
Also, I just recently replaced the head gasket on my Accord. Everything ran fine. Now, after pulling the lines, I get blue smoke out the tailpipe. Quite a bit actually. I know this usually indicated valve trouble of some sort, but why wouldn't I have seen this prior to removing the vacuum lines? Could this have something to do with the fuel/air screw?<br><br>
Thanks in advance.
