Car wont start after i wen out of GAS
My fuel-filling pipe have rust (leak),so my car have idle problems,so i always trie to fill minimum with gas,i have a reserve-can in my car,i and every time i drive the car until it wont start,it have happend some times now (4-5 times)
Yesterday i was driving and i had very little gas left,after a while car stops and i fill gas,car wont start again,so i rolled it down the street and it starts but there is no power,i push the gas pedal but nothing happens,and it seems like the car is not getting the fuel--What have went wrong?
Honda Accord 1986 EX CARB (manuel transmission)(European versjon)
I checked the filter and it seems fine.
Checked the fuel-filter,it seems fine..Where is fuelpump relay located?I tried to find it,but cant find it...
fuel filler was safety recall
a dealer should change it for you..check the NTSB recall list and call your local dealer...of course they won't jump on a job like that..you may have to make an "appointment"...
I hd the pipe changed in my 87..the rust is so fine it can make it's way past both fuel filters..but the safety issue in case of rollover.
