looking at rims real soon like
I am int he prosess of purchasing pimp88accord ride. Its a monterey metallic green coupe down on sprint springs with kybs. I will hopefully be swapping those kybs out with konis if they they are available here in a month. Anyway I am chosing basicly 2 rimws. They are both available with 17x7.5 with 45mm offset. They areenkei rpm2 and enkei zr1. I like the rpms cause there like a smoked crome and only weigh 16.5 lbs.
If igoo with a 205/40-17 on a 45mm offset rim thats as low as the car, I believe the sprints have a drop of like 2.25-2.5, will I have any problems with rubbing or anything. He rolled the fender lips already so that should help. In past posts you have said the aceptable rims are from 40mm-45mm so I think this should work. Also with this could i go to a 215/40-17 just curious. I have this on the other accord and it will rub a little here and there in the rear even with rolled fender lips. They also have momo sports with an unknown offset. They came off a newer lude though.
Thanks for all the help Mike
