How do I remove the corner lights, to get to the bumper bolts behind them. There are no screws on the lights, I have no idea.
Extend (FLIP UP) the headlights. Then look for 2 holes on cornering light assembly close to the headlight assembly. There are phillips heads screws in there that hold th cornering light on. Just loosen screws and move the light assembly side to side and pull out. There are also 2 guides in the back of the assembly you will notice once you get it out.
Yeah don't try and pull the corner out to the left or right cause the 2 plastic guides will snap..
I'm talking about the lights below the headlights, not the ones to the side.
Sorry. I think those lights might only come out with the bumper. Of course you first have to take connector off to remove bumper fully.
Pull off the the blank off below the light (fog light cut out) and I think you will get access to the bolts for the bumper.
What year is your accord?
hmm well i guess its an 88 or 89... anyways there is a screw under the lights... well it's attatched to the lights. You have to remove the fog light cut out covers and then look up thru the cut outs and you'll see a small hole for a philips head screw driver... just push the screw driver up the hole and turn it till it catches on the screw inside and loosen the screw.
He's talking about the signals on the bumper. To get those out, do what Mac said. There should be one screw to hold each light and those screws can be accessed if you go from under.
Well thats what I said... Mac was suggested removing the entire bumper.
I guess I explain things funny.
There are no bumper bolts behind the blinkers. No need to remove the housing. There is a bumper bolt in plain sight if you pull off the fog light cut out.
I'ma fool... I kept thinking he wanted the signals out... not the bumper off.
Ok don't listen to me guys... I think I've lost it. hehehe
'Tis all good....no one else listened either!! :lol Luckily I actually READ his first post ;) haha j/k
Well guys sorry for starting a spin. After I realized I was wrong in the beginning I did figure out what Krott5333 was trying to do and did tell him to look for the bumper bolts under the fog light cut outs which was confirmed by the rest of you. So in the end we did get him where he wanted to be ( just took the long way)hehe. Any way did you get the bumper off?
