need engine mounts
I need engine mounts for my 88 accord a20. I think mine are bad cause when im sitting at a stop light idling my sterring wheel vibrates and i can feel vibration in my feet when holding the brake pedal, then when i put it in neutral it goes away slightly.
does the motor 'clunk' when you hit the gas? the best way to tell if your motor mounts are bad is put it in gear (or park) when the car is off and rock the car and see if the motor moves. It shouldnt move more then 1/4" - 1/2" MAX.
To me it sounds like your car is just running rough possibly due to a bad fuel filter, dirty injectors, dirty carb, bad/dirty plugs.
how much do new mounts cost? I need some new ones for a swap.
that could be, im stationed in korea for the army and my car is in alaska so i cant go check on that right at this moment, haha but that could be what is the problem, im sure new mounts would be good though anyways considering its an 88 and old plus alaska weather probably wore them out along with other things
they are $36.99 new
if all else I have an '88 lxi good mounts?
I would sell mine for $20+ shipping?
