Originally posted by zero.counter
Make sure that you disconnect the negative cable from the battery when working on your car stereo, I cannot stress that enough.
I tell you what, check your fuses, both the ones on the deck and the car's. If they are good, then check the 12volt switched (red) for continuity or the inline fuse (if it has one). Then the memory cable (constant, yellow) for continuity. Then reground to the chassis, scuff with some number 200grit on the back where the radio sits for a good ground. If it is still not working, and the car starts up, then make sure the speaker leads are not crossing. i heard you say that you were using the pre-amps. Does the head unit cut out the speaker leads while the RCAs are in use or use both? Either way, make clean connections, make sure the wire harness has no loose leads, and if you do manage to get power, hit the reset button (if it has one). Worst case scenario, sell it to a pawn shop or put a "FREE" sign by it on the curb.
I don't want to start anything again, but I don't think it has anything to do with outside wiring if he can squeeze the back of the headunit and get it to work.
