Troubleshooting an electrical problem, please read(EDIT: fixed thanks!)
Ok this is really wierd, this morning, I turn on my car and immediatly notice my rpms reading at 0. First I thought maybe my car didnt start up right or something, so I shut it off started it up again and still had the same problem. Well, it turns out that all of the following things do not work:
Tach
Temp Gauge
Fuel Gauge
Turn signals
Digital Dash Clock
Im working on the problem right now, and I am determined to fix it myself. At my disposal is everything i could concievably need to fix the problem.
So my first question is this: are those components governed by the same fuse / relay / voltage limiter / etc? I am flipping thru a book with lots of scematics but there does not seem to be one for any of these components.
A note on the fuses: I used a test light earlier today @ work on my fuses both under the hood and under the drivers side dash, and they all seemed to work, however I could be wrong because as for the ones under the dash I did not test ones that were labled for things I was not concerned about.
Other than the above problems mentioned, the car runs fine I drove it to and back from work today with no problems other than the fact that the above components did not work.
As I am working on the car I will check this thread periodicly 2nite to see if anyone has some good insights.
Hopefully with your help I can get this problem figured out tonight.
