Someone please help
im in the middle of doing my oil pan gasket and i got all the bolts off and the flex pipe down and now it seems to be caught on the tranny or somthing i didnt take crossmeber down cuz it shouldnt be in the way. does ne one have a step my step intruction pics or somthing. thanks for the help tom:rant:
thanx for the help, well ne way its out, had to take off like 3 more things, and the gasket has 3 tears so i guess thats partially the problem well ill put the new one in and see how it goes.
ok dude this is the steps for removing the oil pan step by step.
works on 1985-1989 all makes of accord and 85-87 prelude si
1-drop the flex pipe.
2-drop the lower crossmember (only 7 14mm bolts)
3-there is a pipe welded into the oil pan on the back of the crank case remove the banet holder on the connecting rubber hose (that is part of the extensive pcv valve system)
4-remove the dust cover and lower engine mount (that connected to the lower crossmember) should be 4 12mm bolts and 2 10mm bolts.
5- remove the (three trillon 10mm bolts holding the oil pan to the block -- lol)
6-wedge a flat tip screwdriver between the oil pan and the block and pry the oil pan loose working all the way around the oil pan.
7-after breaking the pan loose *simaltaniously* pull the oil pan down and at the same time while pulling it towards the driver side of the car.
thats it man. but watch your eyes, cause when the pipe lets go it tends to fling excess oil in the pipe everywhere
Lemme know how it comes out when yer totally done, I need to do mine here in the next few weeks
ok i got the gasket and the sealant can some one give me a how to, or some pictures becuase i need to know how u use the sealant and shyt
thanks tom
i already got the pan out i just want to know how to use the sealant and shyt or see some pics on it
ok cmonn 3geez PROFESSIONALS help me out i need to know how much sealant do i put and where and whats the torqueing sequence ........:crying:
even if you could post some pictures from haynes repair manual would help ........:huh: :rant: :mad: :wtf: :crying: :burn: :bow:
thanks guys i got to get to work tommorow looks like im going to be up till midnight
manual says to put silicone in 4 spots on the pan, the four corners where the hump in the pan are, thats it, then put the gasket on over the 4 spots.
aiight guys all done no leaks from the pan now but there was a tiny leak be4 they guy had messed the oil pan gasket up and now i fixed the oil pan gasket and its got the real little leak but its weird the little drips are comming from the iming belt cover area
its like a lil more then a teaspoon afta a 30 min drive comming from the timingbelt bottom , and there is some weird noise when u give it more gas than normal driving or givin it alot it like clings or pingin or suttin i wanna fix that
also where would my timing mark be we looked all over
also im getting a clicking from my distributor
