Single cam screamer / D-series idea
Call me crazy... go ahead...
Now that I'm in the terminal stages of shoehorning an H22 into my 3G, I'm considering the use of a SMALLER ENGINE in the next project car.
So, the idea is to use an abandoned D15 or D16 engine (from older Civics/Tegs), turbocharged, to make up the heart of a potent 3G toy car.
Buy D15. Do rebuild, including lower compression pistons (8.5:1? 8.0:1?) and stout rings. Maybe use some reinforcement on the cylinder walls... then add a Garret T25 from an SR20DET. Electronics are a bit of a mystery. Probably Hondata if money's not an object, modified stock computer with some fpr tricks if it is....
This type of configuration reportedly makes 170whp @ 6-7psi. With the 8.5:1 cr and a different turbo, who's to say that 250whp is not possible? I think it is. At only 12psi? Hmm...
There's a few production cars rotting in junkyards these days with Mitsu turbos just begging to be put to good use.
And, the D-series is SMALL. It will FIT inside the engine compartment without doing 40 hours of BANGING, CUTTING, and WELDING!
It's an idea.
