The stock Accord seats are not very comfy especially on long rides. I was considering selling mine for this reason but I really like the rest of the car. I had some spare time on Tuesday and did the junkyard stroll for a driver's seat swap. The one I found that matches up the best and is very comfortable is out of an 88 Celica GT.
This seat has lumbar, backrest, and seat adjustments. It is softer and much more supportive than the Accord seat as well. 3 out of 4 hold down brackets from the Celica seat can be used with little modification. The front 2 brackets just need to have holes drilled and relocated and the rear right bracket needs to be removed, turned upsidedown, and drilled for new holes. The rear left bracket is fine as is. The front left side bracket will need a small support underneath it, I used a small cut from a 2x4.
The Celica seat sits alot lower so this mod is more suited for taller drivers.
I am definitely going to keep the Accord now with mod. Toyotas do have their uses!
TC
'88 LXI Hatch
