the pcv is so dam tight in the hose ,how to pull it out? :mad:
Get some needle nose pliers or some smaller vice grips and just pull!
Be careful though... i heard of some people breaking the pcv valve partly in there which then is a huge pain!!!
So consider carefully if u wanna open a can of worms if its been in there for ages.
Twist and pull at the same time to get off the hose.
Exactly. Grab the hose w/ the pliers, applying moderate pressure. Rotate the pliers to the left and right until the hose breaks free. Then start pulling back as you rotate the pliers until the hose slides off.Quote:
