Engine light but no ecu code?
Hi!
I have a Accord 89 ex-i and I had a problem with cylinder 1 not firing... I found out it was a solder in the ECu that was damaged... Now, all 4 cylinder are firing...
The first time I started the engine, It was idling high and funny with the engine light on and after 30sec, everything was ok and light was off... Figured it was the ecu getting all signal from the sensors... I also found a vacum line that had a hole... repaired that...
The next day, came back to idling high and funny (back fired also) with engine light on... But does'nt come back to normal... Tried resetting the ECU... Same thing...
Then I came to your site, looked how to check the codes from the ecu... If I understand correctly: While the key was on (without engine running), the ECu should blink on it side from a led... But my problem is that the light stays on... No blinking...
Is it normal? Or my ECU has another problem (defective)? What should I do or check? I'm thinking of change the ecu but they are hard to find in Montreal because they tend to be water damaged or to must rusted...
L8r
