what kind of adjustable feul pressure regulator? namebrand....most importantly is it a 2port or 3port and which side of the feul rail did you mount it feed or return?
i think turbo accord has something on this on his web site
I'm not 100% sure on this but isnt it the b&m one that requires you to cut the top off your old regualtor and replace it with the new b&m piece. It uses the stock fuel rail and lines.
andy
You can use either the AEM style one, or the vortech or the B&M, but it requires you to do a little modifications. I have a how to on them on my website, or I can make it for you---ready to bolt on for $85..
Justin -
What stock regulator do you use for your Vortechs? I have one, and I can't find ANY 3g's with a regulator small enough to fit it.
-5150 http://www.automotiveforums.com/vbul...ies/bandit.gif
Look on my how-to section for adjustable fuel regulators---
Here I will even make it easy for you:
(Just click the link below:bh:
http://88turboaccord.net/installations/fuel/
I followed the howto, but the prolem that I'm running into is that the stock regulator is too large of a diameter for the Vortech to fit.
To make a long story short...
http://88turboaccord.net/installations/fuel/img18.jpg
That won't fit INTO the Vortech FPR.
-5150 :bandit:
Does the part # on yours match the one on Justin's page??
Yep. The only difference is mine is purple.
-5150 :bandit:
It is a stock fuel regulator---any hOnda works, even ours, you are not doing something right...
I followed the instructions, cutting the top off the regulator... it's that the bottom half won't fit into the top of the Vortech... it's too big around. Do you need to grind down part of the bottom so that it'll fit? :confused:
-5150 :bandit:
It took me 15min's to put my adjustable feul pressure regulator in and that cutting it to. http://memimage.cardomain.net/member...7_149_full.jpg
