Alignment and suspension stuff
Maybe you've read my post about the sad sad story of a girl who was stupid. Maybe not. But this post relates to that.
So, anyway, I have two new tires on the front. I don't have a lot of money, so I didn't get Eagles or Potenzas or anything like that; I got Daytons. Blast me if you want, but I'm a civil servant and I have a mortgage.
Anyway, the old tires were extremely worn on the inside edge of the tread (the side of the tread toward the car). This obviously means that I have too much negative camber, and I will need to get the front suspension aligned soon.
However, there are things that make me think the problem is worse than can be cured by a simple alignment. The left front corner of the car groans when the suspension flexes. I think the strut needs to be replaced. I am sure that this is one of those things that should be done in pairs, so... here's my question:
If I don't want anything special, but just plain OEM stock struts, how much am I likely to have to pay for them... and have them installed? (The last time I worked on a car's front suspension was when I replaced the inner control-arm bushings on my 1971 VW Super Beetle, and that has been 6 or 7 years ago.)
Re: Alignment and suspension stuff
I was getting what looked like wear from excessive negative camber. It turned out that my toe was off and my camber was within specification. You can estimate your camber by measuring the position of the top and bottom of the wheel relative to some known vertical surface. A little trigonometry will tell you your approximate camber angle.
