Crankshaft Pulley Removal - Help!
. . . my ignorance & stupidity continue . . . I skipped trying to remove the intake manifold and started working on other stuff . . . like removing the crankshaft pulley . . . I'm reading the Haynes manual and it says on page 24 (after aligning the flywheel timing mark):
Now pass a bar or thick screwdriver through one of the cut-outs on the pulley and hold the pulley still by leavering against the crankcase while the pulley bolt is unscrewed and removed in an anticlockwise direction.
Are they kidding?
I mean I've tried this every way I possibly can and it's no use . . .
. . . by the way, I already cut the timing belt after having it aligned TDC and marking the cam pulley . . . but . . . while attempting to remove the crankshaft pulley, if I turn the crankshaft pulley counterclockwise past the timing mark just a little, is it okay to turn it the opposite direction to line it back up?
. . . I'm such an idiot . . . Honda's might be great when they're put together and running well, but working on them is not my idea of fun . . .
. . . thanks in advance . . .
IPF
:banghead:
