Fun times with the rear brakes last night... :) Long story short, I got the passenger side done which was scraping. Felt great about my first drum brake change, although I was thinking WTF when all the parts came out, even when I had them lined up as they came out in order. Good thing I have two drums to compare. :) I underestimated how strong the return spring is, and struggled for nearly 30 minutes on getting enough pull to snap it to the other shoe.
However, on the driver's side I found a trick, but I think there was air already in the brake lines even before I started. The driver's side cylinder would push the opposide side out, each time I pushed on the other one. The passenger side didn't do any of this, they both went in nicely separately.
Anyway, I accidentally pushed one side of the cylinder right out, and brake fluid seeped out... YIKES! I cleaned it and set it back in place and it worked fine, but I got some air in the system and my fiancee was in bed, so no bleeding of the brakes took place last night.
Anybody had similar experiences?
