Not a bad deal I think
some sprint lowering springs 2.25
http://i19.ebayimg.com/02/i/01/0b/fc/e4_1.JPG
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448455837
ya thats not bad at all. I have sprint, but you got a damn good deal. What " drop did you get?
yeah sprints are good springs. the only little problems i have is that they lower the car so much (2.25") that on the front you have to fix your camber with either a camber kit or 84-87 prelude upper arms, and the rear sits too low for 18 inch wheels like i have so you have to roll your fender lips to keep it from cutting into the tire, not hard to do. if you have smaller wheels then you shouldn't have that problem. also try to have the hardest shocks you can buy since these springs have kinda soft spring rates and have little suspension travel and will bottom out if your shocks are weak. i have konis maxed to the highest setting and they do an awesome job at keeping the suspension stable. also, new shock bump stops and mounts are a must.
