Here is my current weber 32/36 setup... (CARB w/ MANIFOLD FOR SALE $160)
The 1" spacer)
Drivers side)
You'll need to use a 1" tall filter instead of the 2" filter to get the hood to close.
Damn...nice setup. Why are you selling, though? Going F/I?
nope, he is going Holley.
sweeeet... my dad and I dropped a 5.8 liter into our full-size van, then slapped a Holley 4 barrell on there, upgraded the exhaust and intake, and DAMN can that thing go! it pulls the boat like it wasnt there... mmmm, torque
Here is my mini muffler I stuck on backwards... :rolleyes:
I sound like a truck and it makes the loudest backfires when I downshift to slow down.
You are selling? I need a weber carb for my 86 accord... so how do I go about working out the deal with you?
Are you Automatic or Manual Trans?
Other then that I can sell the carb as is but you might want to read up on it.
- Adapter Plate has a 1" spacer added for better fuel flow
- Intake Manifold has a ported plenum for increased manifold volume
- Carb jets are rich at idle and 2 of the jets are not the correct size, however for about 5.00 each you can buy the jets you need yourself
- The Air Filter is too tall to be used with the stock hood on, however you can buy the 1-5/8" tall filter and it should let the hood close properly.
- Throttle Linkage only has one slot for the throttle cable which should work fine with the stock throttle cable
- Automatic cars will need to make sure they have the TV / Kickdown cable hooked up properly for their trans to shift properly
- Is ment to run without intake manifold heater, you will need to bypass the coolant ports on the manifold or plug a port on the intake manifold as described in the weber install how-to on this site
- As is this isn't ment to be used on emission regulated cars... so check your state laws
man that looks amazing ! :)
Mike !
Well I decided to buy a brand new Weber 32/36 kit, heated base, progressive, electric choke :-) I just cant wait to install it, will be a fun project, + if I'm getting the chome airbox, might as well pain my valve head and get colored spark plugs etc.
The new weber 86 Honda kit, is $379. :-O Hope its worth it.
Did you get it yet?
No not yet, because someone told me im better off upgrading my exhaust first, well im very tight on money, and I really want teh weber, so I am not sure right now.Quote:
Originally Posted by A20A1
man on man i am dying , i want this , but i also want to fix my transmission mount and payfor my insurance but your on my "to do" list. oh and could you get me a shipping quote to L9N1J5 [Ontario, Can.]
Well turns out, I found a place selling the 86 weber conersion kit for only 359.. but I went back to the other place and they cut it down from 379 to 357 :-)... not a bad way to safe 2 bucks, point being I got them down 20 bucks. (Not to mention, shipping is included :-) sweet. Now to find a good deal on exhaust.
does that pass inspection ?? or r u one of those lucky ones that dont have inspection in their state ???
We have inspection.. but its not for emission, its for your basic windsheidl, taillights, headlights, horn, and turn signals :-) thats the only inspection we have.
What store/website sells this kit for our Accords? I want one.
nice setup a20a1 i have something simaliar but no 1'' spacer and a ramflow foam filter the egr vavle was removed and cover though
I still haven't gone to the tracks to test my header... but I expect to get a good ET and 0-60 or 60' or whatever after I change the fuel pump... I've been putting it off cause I'm still not sure how long I will be keeping the car. I may be forced to get rid of it... which I hope never happens. I want to double check on the clearance issues with the 1" space before I sell the carb. Or you could always install a hood scoop. :D
These people sell the Weber 32/36 conversion "kit" for the 86-89 accord. There are actualy a lot of ppl who do, because weber actualy makes this kit specificly for out cars :-)
http://www.carbsonly.com/ $379
http://www.carbs.net/ $359
Includes everything so it says. Shipping price is usualy already included.
-JT
