2G Carb Question - This Is Driving Me Crazy!!!!!
Okay, I'm trying to get my car to run after having the head off & checking the valve & ignition timing . . . they're both fine . . .
. . . when I go to start my car I can smell gas and when I look down into the middle barell there is a sizeable puddle of gas at the bottom flap (butterfly valve?) . . . I sopped up the gas with paper towells, being careful not to let any paper bits get into the carb . . .
. . . when I open the carburetor manually I can look down into the carb and the middle butterfly valve does not open . . . I can go over to the right side of the car and manually open the two end valves/flaps as I pull back the throttle cable, but I thought this middle flap was supposed to open along with the others automatically - yes? It does not.
It seems to me there's a linkage that opens the middle flap which should be "sprung against" the main linkage connected to the throttle cable and there is an obvious groove in the throttle cable linkage for the middle flap linkage to "follow" . . . but it doesn't . . . I disconnected the shaft at the bottom of the secondary diapragm unit . . . still, the middle flap (butterfly valve, whatever) doesn't open . . .
Does anyone have any clue how I can fix this mess?
Thanks,
IPF
:gun: (my car)
