Hello People,
Ok here is my problem. I just bought my accord about a week and a half ago. The stock radio works and doesn't work. Not sure if it's just because it's aged or something. Sometimes when i start the car it works right away, then about 2 minutes later, nothing. Sometimes when i start the car it doesn't work and then about 5 minutes later it works. I also have problems like it working for a while then it stops working.
I've completley taken the head unit out and checked to make sure there was contact on the antena and on the power/speaker cable connector to the radio, doesn't seem loose at all. i checked the wiring as much as i could to see if it was cracked or anything. couldn't really see much since it is all taped up etc. I checked the fuse on the back of the radio and under the dash next to the steering column, seems good. Not sure what else i can check.
I know it's probably better to buy a new radio/cd unit but at the moment i don't wish to spend money on something like that, as the car needs some body work etc, prefer to concentrate on that.
Any suggestions or ideas would be great. thank you.
