Factory Specifications and Dimensions: 1989 Accord DX 4-Door Sedan
-Engine-
Type:Aluminum head in-line 4
Displacement (cc): 1955
Horsepower @ rpm (SAE net): 98 @ 5500
Torque (lb-ft @ rpm): 109 @ 3500
Compression Ratio: 9.1:1
Valve Train: SOHC, 12-valve
Fuel Induction System: 2-Barrel Carburetor
Ignition System: Electronic
-Drive Train-
Type: Front-Wheel Drive
Manual Trasmission with Starter-Interlock System: 5-speed
Automatic Transmissions w/Lockup Torque Converter and Shift Interlock (Available):
4-speed
Final Drive Ratio (MT/AT): 3.866/4.066
-Body/Suspension/Chassis-
Body Type: Unit Body
Suspension: 4-Wheel Double Wishbone
Stabilizer Bar (mm, front/rear): 18.5/NA
Steering Type: Variable Assist, Power Rack-and-Pinion
Turning Diameter, Curb-to-Curb (ft.): 34.8
Dual Diagonal Brake System: Front Ventilated Disc/ Rear Drum
Wheels: 13-inch Steel Wheels with Full Covers
Tires: P185/70 R13
-Exterior Dimensions-
Wheelbase (in): 102.4
Length (in.): 179.7
Width (in.): 67.4
Height (in.): 53.4
Curb Weight (lbs., MT): 2500
Coefficent of Drag (Cd): 0.32
-Interior Demensions (Front/Rear)-
Headroom (in.): 38.7/37.7
Legroom (in.): 42.8/32.4
Shoulder Room (in.): 54.9/54.5
Hiproom (in.): 52.8/50.0
Cargo Volume (cu. ft.): 13.7
Interior Passenger Volume (cu. ft): 104.3
-Capacities-
Engine Oil with Filter (qt.): 3.7
Fuel (gal.): 15.9
Cooling System (qt, MT/AT): 6.6/7.3
