Intake Problems!
I have a 86 EFI 5 speed and I have just put a cold air intake on it but on the stock intake there are 4 lines that hooked into it, the two on the drivers side are the ones that I am inquiring about. since the box is gone that they were connected to, where do I connect them now? Is there a way to bypass them? I know that the one line connects to solenoid on the drivers side of the intake. Also since I have put this on my PRO-EFI light comes on after about 10 mins of driving. What is this? HELP PLEASE!
N/M, guess i didnt look hard enuff, my bad.
https://www.3geez.com/showthread.php?t=6791&page=2&pp=20
But after i fixed all that the P-EFI light still comes on after about ten min of driving. anyideas on what might be wrong?
Unhook the negative battery cable to reset the ECU, then re-hook it and see if the code comes up again, then if it does check the ECU code thread in this section.
