For any one doing the weber conversion it is a must that u get a better fuel pump. A fuel pump that rocks 4psi's thats wats requiered and high volume for a steady fuel flow. The reason for this is that the stock fuel pump does not send a steady fuel flow at low rpms because it pluses the fuel. It cause the weber to boggle in the low rpms. A bigger filter is also good more air more fuel.
there is a cheap velocity stack set at A DGV remote filter adaptor and a poly utherane velocity stack from webercarbs.com or a ram flow filter.
By the way make sure u spray the linkages wit slicone spray or go to a bike shop and ask for teflon juice it doesnt brake up in wet weather.
