Facked my civic adapter i think
I need to get a pic of it but man, i got it...and started filin some stuff(no dremel) to get it to fit and i think i filed the wrong spots and i have a bunch of holes now. i dunno...its pissin me off...i dunno if this made since but thats probly cuz i am really pissed off
I Did It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WOO-HOO! I am the man. Weeeeeeeeeeeeeeeeeell, I got a drill bit that is used to shave off plastic, wood, and something else. But i used that carefully and fit it onto it almost perfectly. used the file so it cleared the float screw(i guess thats what it is...yellow and a lil up and to the right of the carb opening) and made it where that went flush...then i used the door weatherstripping that had fallen off earlier and wrapped that around the opening under where the rubber gasket from the old one went...fits perfect with a lil cutting...then i check for leaks-none! so i put the lid on and of course it hit the top...i tore the box it came in apart and used that as the lid til i could get to the hardware store(a minute away) where my dad works part-time...i ran back to the back and got an 8" x 18" aluminum sheet and cut it in half with a hacksaw...i then drilled the holes for the screws in it and came home. i got home and placed the screws in the holes and started screwin in...it bend into place by itself...i then got a hammer and carefully hit the edges so it bent down...it fits absolutely perfect. i put the hood down and it latched perfectly!!!!!!!!!!!!!! SUCCESS! i will get pics of it as soon as i clean the engine bay...man, it wasn't that hard. just a lot of time and patience to get it drilled just right...i drove it around and i can feel the difference. i need to get the piping and the filter now....i am currently using the tube from the civic and it puts the tube right behind my battery. it is filterless right now but i won't be driving it more than 2 miles right now...my dad is gonna bring home a small filter to place in the air box temporarily... :cheers: all i gotta do now is make it a real cai!
